Hi all,
The board are coming to move my meter next week and I want to make sure I have all the cabling done before they arrive. Currently I'm on an overhead feed and the earth is via a spike in the ground and then what looks like a 6mm cable to the existing meter.
The meter will be moved outside on the wall above where the spike currently is. Do I need to upgrade the earth cable/spike to a larger size and should it be protected in any way up into the meter cabinet (its not at the moment)?
Can I also get your opinions on the following....
1. From the new meter (Currently it has a 100A fuse on the head), I'll connect the tails to a MEM 80A switch fuse ( via 25mm tails).
2. From the switchfuse to the (new) MK consumer unit, i'd like to run 16mm T&E (approx 6 meters) - Will this be ok? (FWL did say to use SWA 25mm but I'm struggling to get that fed through, plus I think I read soimewhere that the Sentry CU's only take 16mm tails?).
3. If I can use the 16mm T&E, will the earth in it be sufficient in size or should I run a seperate 10mm/16mm for it?)
Thanks in advance
Neil
Thanks in advance
Neil
