Sizeing / sealing new plaster
23 May 2006
Is sealing new plaster still done with a watery solution of wallpaper paste or have the techniques changed over the years? The plasterer recommended a watered down PVA mix if I am to paper the new walls or a mist coat if I am going to paint directly on to the new plaster.
I think that I would prefer to line the walls first with lining paper and then paint just because I will know that when I re-decorate, there will never be a problem with flaking paint that I can't solve by just stripping the lining paper. What do the professionals think?
3 Feb 2012
Blackpool
Absolutely no need to line freshly skimmed walls. If painting just water down some matt emulsion. I tend to use dulux supermatt and water down about 25%. If papering use some thinned paste to size the walls. DO NOT USE PVA it is not designed for this!
28 Oct 2005
Don't line plastered walls - that's why you plastered them.
