Hi. I would welcome some advice.
I have just had a room, ceiling and walls skimcoated over newly fitted plasterboards. I intend to paint same and to tell the truth am confused at the different suggestions I have heard.
Some suggest simply Polybonding prior to painting while others say this is a very bad idea as Polybond will not let the paint breathe ??? and suggest using a 5 parts matt emulsion to 1 part water mix as a primer followed by a coat of the desired paint. Others say the paint / water mix should be 50/50, a mist coat then the paint.
Others suggest sanding the skimcoat.
I was thinking of waiting until the skimcoat appears to have dried fully then waiting a further 4 days ( to allow for the bits that may be only surface dry before painting. Would this be enough time.
hitbit
hitbit
