Skiming the ceiling with a loft hatch gap
1 Mar 2017
Hi all,
I'm new to diy'ing and happy to try most things. However the one thing I'm reluctant to do is plastering so I'll get someone in :-)
In saying that, we have just made our loft hatch bigger and now want to skim the ceiling and put some architrave around the loft hatch.
If you look at the picture there's quite a big gap on the right hand side.
Will a plasterer bond and plaster over this gap (approx 2 CMs wide and 1 CM deep) if you poke your finger in 1CM you'll hit some wood.
Or do I just get a bigger architrave?
I'm not sure what's best to do or best to suggest to the plasterer.
Thanks.
Looks like you can cut a strip of plasterboard and screw it to the wood then put your architrave over it
Thanks Steve.
Also just though; should I put the architrave up first then get the plasterer to skim or get the plasterer to skim up as close to the edges as poss and then put the architrave up?
Cheers
It dosent really matter to much but If that was me I would put architrave up first normally around doors and such I skim first but on this occasion I would architrave first
