Looking for some guidance, about 5 years ago I did some skimming, it was a house I was renting and to be honest wasn’t happy with the finish, it was my first attempt and with a bit of sanding it was ok for renting , well I didn’t get any complaints about it.
I seem to recall me main problem was with the second coat of skim, most went on ok but started to get `holes` and when I tried to flatten/fill in it went from bad to worse. I eventually filled them in after it was all set and sanded flush.
Moving on 5 years and recently moved house......
Stripped the wallpaper off and the walls are chipped, gouges and pin holes, now I know why it was papered in heavy embossed paper 
I started filling in with a standard filler but although much better was taking forever and needing sanding in between, I thought about skimming but remembered my last attempt. So having plenty of filler I though stuff it and mixed a load and applied in broad sweeping arcs, going over it where necessary to flatten and spread it out similar to how I used the skim last time. Lo and behold I was more than happy with the finish apart from where I tried to `feather` the edges as it seemed to dry out and go patchy.
Anyhow I am now thinking that one issue I may have had when skimming was being too finicky and trying too hard, with the filler this time I was more relaxed and prepared to line the walls with lining paper if it failed.
Could it be that my more relaxed attitude helped to apply (ok filler) a better application, and what would cause the `holes` in my previous skimming attempts?
My DIY skills for most things are good and if patching a hole can get an invisible mend can repair woodwork, paint, wallpaper etc, possibly its the attention to detail that screwed my skimming attempts.
I am thinking of having another attempt at skimming as I still have a couple of walls to do.
Thoughts appreciated.
