Slate roof major overhaul - Glasgow
4 Mar 2007
Glasgow
Mine is ageing & showing signs of minor leaks - nothing catestrophic. We're considering our options. We've spend a few £k in the past few years, so its approaching the point of replacement we feel but its abig cost.
a) continue to patch
b) major overhaul
c) replace completely
Whats the difference between b) and c)? One of the largest issues we have is the 'horsehair' underfelt that seems to degrade into the attic covering it in black dust. Anything to remedy that is welcome.
I'm keen to do somethign to replace the felt with modern equivalent. Any suggestions? Would a major overhaul cover this? is it worth putting the old slates back if they are in a bad way?
Its a complex roof shape but I need some techncial advice before I speak to a local roofer.
View media item 49293
Lastly, whats a reasonable price £/m2 to budget for these works?
i can help you out there, if its scottish slate id take them off refelt roof re-dress the slate then put them back on
Hi, please advise how to get in touch and provide indicative £/m2 or total price. Thanks, GB
I was in the same situ last year. What makes you think you need a new roof? unless over 25% have slipped or it has nail sickness I would stick with it. Scottish slate is surprisingly long lasting and are appropriate for your house. I ended up replacing the flashings and valleys. should be good for another 30 years. Whatever you do avoid the fugly tiles your neighbour has desecrated his house with. I was quoted 25k for a roof a bit bigger than yours in spanish slate.
View media item 56555
Prices to replace the above roof welcome - indicative prices based on area and complexity welcome. I'll then be going to accredited roofing contractors for actuals once I have a budget cost.
Circa 84m2 with various surfaces / shapes. Proabably quite a lot of leadwork required in comparison to most roofs.
Thanks, BD [/img]
Replace with what?
Price will vary greatly between concrete tiles, and scotch slate.
Can you not provide some ball parks for both? Hence the question, as I've no clue. Presume all other costs however r fixed irrespective of slate style. Interested to know installed slate prices for both in £/m2
