Hi All,
I think I've decided to go with a sleeper retaining wall rather than gabions ( //www.diynot.com/forums/viewtopic.php?t=192429 ).
My plan, after reading lots of posts on here, is to set sleepers in concrete vertically and then screw horizontal sleepers to these. I'll put a vertical sleeper at each end, and one in the middle of each horizontal sleeper, if that makes sense
I'm planning on screwing the horizontal sleepers to the vertical ones using Timberlok landscaping screws, but my question is what size I should buy (I need to buy a LOT of them !!). Since the horizontal sleepers will be 100mm wide I was thinking of using 150mm Timberlok's which means they would go 50mm into the vertical sleeper when I screw them together - is this enough ? The alternative is to use the 200mm Timberlok's but these may poke out of the back of the vertical sleeper by a mm or so . . .
I've just bought myself a Makita BTD130F cordless impact driver to put the Timberlok's in with, so I'm hoping this will do the trick !!!
Anyone know the cheapest place to buy Timberlok landscaping screws ? The cheapest I've found so far is Bunny's Bolts ( http://www.bunnysbolts.co.uk/fastenmaster ) - I think I'm gonna need to two of the 250 pails . . .
Thanks,
Chris
Thanks,
Chris
