I was doing some work at a relative's house last week and noticed that there was a drip from the boiler. It's from the hot water (taps) connection.
When I mentioned it they said it had been like that since it was installed a couple of years ago and as it was a slight drip the plumber when called out did something and said if it still drips just wait for it to seal it self.
Now it is still leaking slowly and has a quite a bit of muck(?) stuck on the coupler. They just keep a saucepan under it and empty it every so often.
When I noticed it I said I would replace it when I next visit, but I'm not quite certain what I need to do.
It looked to be a half inch screw fitting coming out of the boiler and is a 15 mm pipe connected with just a compression fitting.
Can I just take another one off any 15 mm compression coupler in my toolbox, clean up the pipe and put it on? Or should I get a "WICKES FEMALE IRON STRAIGHT COUPLER 12 X 15MM" and use that (I think I might need to shorten the pipe slightly)?
I was going to go with the first option but then I got confused about whether I would use ptfe tape or not then I wasn't sure if they were actually 1/2 inch.
This forum is where I usually find my answers when I have a DIY question but I can't quite seem to find my answer here or anywhere else, so I've finally joined and posted.
Thanks in advance
Aaron
Thanks in advance
Aaron
