Board construction or lining (even cement board) will always be subject to a degree of flexing & movement just through normal expansion & contraction, especially stud work. For this reason you should always use a flexible tile adhesive & grout over boards. CTF3 isn’t flexible & although you can improve it with Admix AD1 but it won’t be as good as a proper flex addy; depending on your tiles size/weight you should have used either this;
http://www.bal-adhesives.co.uk/products/white-star
or this;
http://www.bal-adhesives.co.uk/products/rapidset-flexible
+ primed the PB/plaster skim with this;
http://www.bal-adhesives.co.uk/products/prime-apd
to prevent any reacting between the cement & Gypsum.
Cement powder addy is usually only necessary when tiles size/weight gets near or exceeds 300 x 300mm, was this a reason for choosing it? The primer is also important to avoid any reaction when tiling over Gypsum plaster or boards. The other thing you should be aware of is their is weight limit 32 kg/sqm for unplastered boards but this drops to just 20 kg/sqm when skimmed & this doesn’t include the weight of 2-4 kg/sqm for the addy & grout, depending on what type of addy is used. The grout should be OK, had a quick look & it appears to be flexible.
My biggest concerns would be that;
• you’ve not used a flexible addy
• not tanked the PB before tiling
• did not prim the PB/plaster skim to prevent a reaction between the cement & the Gypsum.
Now that’s it’s all done there is little you can do now except finish it off & see what happens. To a large extent it’s going to depend how heavily used it is & how much water you splash about. Many new builds are done to the absolute minimum spec. but this is probably more through builder cost cutting than a lack of understanding of suitability of the materials; the problem is that they tend to have a relatively short lifespan, in many casses less than 5 years before it all has to come down & be redone; you wouldn’t believe the state of some of the plasterboard behind the tiles that I rip out during refurbishments, sometimes on quiet relatively new properties.
