We've got an open system with a minimiser SE boiler. We moved into this house in May last year and the boiler kettled a lot so over the summer I added a sludge remover to the system, ran it a bit, drained it and filled it back up. It ran fairly quietly until recently. There's a bit of kettling now and a bit of whistling shortly after the burner lights up. This whistling def does not come from the fan as I've tested it separately.
When I came home today the boiler woudn't stay lit. The fan came on, the gas valve opened and the burner light came on for 1-2 seconds and then went out again before the gas valve closed. I had a look at the control board and the number 2 LED (lockout) comes on after the burner shuts down. I tried to light it several times to no avail. The CH and DHW both seemed to work. I went in the loft to have a look at the F&E tank. Suspecting that there wasn't enough pressure in the system I made sure that nothing was obstructing the output of the tank and I topped it up a bit by lowering the plunger. I noticed that that there was a lot of sludge in the tank (brown and black).
When I came back downstairs, I tried to light the boiler again and this time it worked. It's been working all evening with several light-ups as commanded by the thermostat.
I feel none the wiser as I have no idea what the problem was and suspect that it will come back. Any ideas? It has been very cold recently (-4), so perhaps that's got something to do with it? What about the sludge in the F&E tank, I didn't think that there was anything in there to corrode, so is it normal to have sludge there? Our water cistern which is next to it has (thankfully) no such cr*p in it.
Thanks for your help.
Glider26
Glider26
