small crack in base of cold water tank
14 Aug 2010
Buckinghamshire
Can anyone advise on a small crack in the base of my plastic cold water tank. Is it possible to repair it. It must be resting on something quite small as you could cover it with a 10 pence piece. It is leaking about a mug of water per day.
Appreciate any advice.
Mark
28 Jun 2005
not a good idea :cry: in fact I`d say get a new one - on your house insurance :idea:
19 Dec 2007
Lincolnshire
Ditto!! seriously just replace it, if you mess with it is your insurance going to cover you once they find out you have tried to fix it?
14 Aug 2010
Buckinghamshire
Thanks Fellas,
I'm in the game and would recommend the same to my customers but I won,t have a day off for at least two weeks trying to finish a job on time. Need a quick fix to tide me over. What do you make of a piece of plastic epoxy resined over the top.
Just as a side, I didn't think insurance covered the repair/source of the leak?
Best
Mark
14 Aug 2010
Buckinghamshire
I know I'm not a damsel in distress but would still appreciate some assistance from the brotherhood
Regards
Mark
9 Dec 2009
Lancashire
pass but it might work
1 drain it
2 get peice plastic flat possibly from square gutter fixing
3 try using solvent weld for pipes to glue it in place put something heavy on it
4 refill when come back from work
tell us if it works
30 Jul 2006
Hampshire
Very temporary, but quick, and no need to drain the tank - How about a doughnut washer, something flat and something heavy.
Place the doughnut washer to surround the crack, something flat to cover the top of the washer, maybe borrow a teaplate or saucer from the kitchen and weigh it down with a brick to stop it moving.
Once some of the water trapped inside the washer has leaked out, the water pressure at the bottom of the tank should help hold everything in place.
10 Jun 2009
Suffolk
FFS it would take 1-1/2 hours MAX to change the tank after work tonight if it were my house thats what I would do!! (I came home a few years ago to a leaking HW Cylinder that was 4-30PM by 8-00PM I had obtained, and installed a new cylinder) surely you would do whatever to protect your property, if you bodge up your tank and then it ruptures bringing down ceilings and destroying your furnishings and the insurance co finds out about your "repair" do you think they will pay up for the damage --- I THINK NOT :rolleyes:
14 Aug 2010
Buckinghamshire
Problem solved. Drained down the tank as I couldn't risk a flood as Boilerman rightly pointed out.
Presumed crack was a mark from all the crap in there. Cleaned the tank and went to refill still flummoxed to the source of the leak. Water spewing out of the top of the inlet valve.
Must have been breaching the lid, running down the back of the tank and dripping off the middle of the base. 5 min job to change valve.
Thanks again!!
2 Aug 2010
Manchester
Cant understand why if youre "in the game" take it you mean plumbing/ heating, you would ask the question in first place, if a plastic tank is leaking, what does it take to replace? Not much that 4 sure, infact easier than the other bodges suggested, and will actually work :rolleyes:
19 Jul 2007
1 drain it
tell us if it works
Cold water tanks are Polypropylene.
Solvent cement will not work.
