Small extension for gas fire flue?
28 Nov 2010
Edinburgh
I have a Gazco stove (gas "woodburning" stove). I had it removed last year, it wasn't set into a fireplace, more just a hole in wall where it joined flue. I am thinking about having it put back because the (annoying and embarrassing...) column radiators I had fitted at the same time are not up to the job. I know I'll need to place a hearth of some sort again too.
I put a vent in my wall where the metal flexible flue was, but although the flue was connected it was oh by gosh tight. I'd say by the skin of it's teeth long enough. It's not at all easy to get any pull through and quite sticky in it's path.
I really think it needs to be a bit longer to work with. Is there extension parts which can enable this? I know I need to get it fitted by a professional but wanted to ask. Thanks
