Has anyone fitted a freestanding stove with a rear flue outlet that goes through a metal plate covering the original fireplace?
I moved into a house with a gas stove that was fitted in this way. The plate has a hole for the flue and a small cutout (60mm x 80mm) at the base.
I have bricked up the original fireplace and want to re-fitt the stove. Should the cut-out be their? What is it for, and shouldn't the plate be gas tight?
Also, as I have bricked up the fireplace (leaving a hole for the flue pipe), do I need to install the metal plate at all.
Any help/tips would be appreciated.
