Small gap remains after laying laminate
9 Nov 2007
Hi
I have just sucessfully laid my first ever laminate flooring. All 25 sq meters of it. While the room was still full of furniture. :shock: I have used the proper DPM and green fibre boards to give the best soundproofing and good level finish. Went down easier than I thought it would.
I have removed skirting to give a better finish (plus skirting needed replacing with something decent and with a decent finish).
Got the the end and found that were it nearly meets the other wall the gap tapers. So much so that any skiting covering it would leave a gap at one side. A found out today that I can no longer kneel or crouch.
Some options:
1) Try and move the whole floor at one side to try and level the gap. is enough at other side (floor unlikley to move its full of furniture and i would have to standing on the floor). :?
2) Lift the floor and re do it, or some of it. errrm dont think so. :shock: :evil: :shock:
3) Put on skirting then edging strips (however was wanting to avoid edging strips, which is why i took the skirting off in the first place. :(
4) Use the remaining pack of laminate and create a long thin strip to fill the gap (probably about 3/4 board lengths). This also crosses the doorway. Probably about 2/3 cm at one side tapering to about 1cm :(
5) Try and find really thick skirting :D
Any suggestions
