Have you upgraded the smartcom firmware to version 3 and the panel version to 5.04.01 (grade 2 panels only)
Smart com firmware can be upgraded by placing the engineers code in the app and clicking on the i icon top right.
Panel firmware can be upgraded with a Premier Elite Flasher, or remotely via TCS if you have a version 5.0 or above and a smart com.
We can initialise the remote panel firmware upgrade FOC, however this means we would add you to our TCS, then remove you from the system once complete so we are not charged, this is only available for panels below version 5.04.
Taken from the Texecom Bulletin:-
"For Grade 2 Premier Elite systems installed since June 2019, we recommend upgrading to the latest firmware (V5.04.01), to prevent undue stress to revision 5 1.5A and 2.5A PSUs. The upgrade can be done remotely or at the next service visit. Once updated please program the following:
- Change the Battery Test Timer to 0 seconds. (Global Options, System Timers)
- Change the Battery Test Period to 0 hours. (Global Options, System Timers)"
PM if this is something you require, whilst the process is relatively easy and quick, it does take some time for it to go through the motions.
