Smeg dishwash leaking at airbrake chamber (model DFC612S9)
22 Jun 2012
Renfrewshire
Hi All, I have water leaking out near the top of the airbrake chamber. I have replaced the O ring seal between the chamber and the inside of the dishwasher and tightened it well, but it still leaks. I'm wondering if the water is coming out the top of the airbrake chamber (the rectangular opening). I'ts quite hard to tell as it sits so tight against the machine.
my question is, if the water is coming out the top of the airbrake, what should I check? Thanks in advance!
Hi Zipper, thanks for replying. Yes, there is water on the bottom tray causing the float to trip the cycle and causing the error.
