Smeg Touch Control Glass Hob Stopped Working
  • Thread starter Thread starter tombliboo
  • Start date Start date
T
tombliboo
I cam home the other day, and found that it just will not come on. I've had it about 5 years so it's out of warranty, does anyone know would this type of appliance have its own fuse? I've looked at the underneath and see nothing obvious.
I have checked where the cabling attaches to the appliance and there is nothing there, plus the connection looks sound. This links to a socket on the wall which is switched on and I have also looked to see if this is fused, it isn't.
From there the cable goes straight back to to my min electricity box, it has it's own trip switch and this also hasn't gone.
A case of needing to buy a new one?
get a multimeter and check at the hob terminals to see if you have mains voltage there ( 230-250ish volts depending on where you live )
if you do then your hob needs looking at... if not then your wiring needs looking at..
easiest wasy it to get a sparky in to check it out for you and advise....
