Smiths Hydronic Plinth Heater
18 Sep 2013
Kent
Hi.
I'm fitting extra kitchen units and need to remove a 1.3m central-heated radiator. The kitchen is 34 cubic meters.
Hence, I am tempted by the Smiths SS5 heater.
Are they a good option, or should I look at a different options? If the latter, which one?
I do have space for a tall radiator on the same wall, but needs to be less than 500m wide and 100mm shallow.
Do these hydronic heaters work with a standard TRV? Can't find any info on this, but can't see why not.
Thanks in advance for any help/advice/tips offered.
I think the normal way to regulate them is with a wall thermostat that turns the fan on and off.
Thanks for the info Newboy.
Is the Myson quiet too?
Why did you opt for the Myson and not the Smiths?
The Myson is quiet on the lowest speed setting (which works fine in the area it's heating)
Went for Myson because:
a) The wall mounted control seems to offer more options - power/fan speed/temperature all of which means there's no need to bend down to the plinth to operate the unit.
b) I've fitted other Myson products and they seem well made.
5 yr warranty with Smiths. More reliable than Myson (we fit them regularly as we're a heating contractor).
The smiths uses a temperature sensor on the flow pipe inside the unit, no TRV is needed or should be fitted. Size the unit to be suitable on low speed metrics.
Well that's cheered me up! :)
That only controls the fan, low flow temperature on flow pipework stops the fan - it doesn't control room temperature (exactly as Myson). External thermostat (wall mounted) is a must for effective room temperature control (optional extras from both Smiths & Myson)
Worth considering!
