This is my first post, greetings to everyone.
We have two smoke alarms in our house, one EI150 without battery, the other EI156 with battery. Some months ago the EI156 started to beep so I just disconnected it. Now we think it is important to have working smoke alarms so we try to connect it back. But we just found that the there is no electricity on the wires to the connectors of the alarms at all.
I've done some basic checks using a multimeter and a voltage test screwdriver. The breaker box seems fine - there is power on the output wire from the breaker for smoke alarms. So it looks like the wire between the distribution box and the first alarm is damaged. Two years ago we had to replace a piece of drywall in our family bathroom and the wire might have been damaged then, though I did notice the wires in the wall and paid extra attention.
The wire goes from the distribution box to the loft first, so I think it will be impossible to pull through a new cable without tearing the walls and floors open. Therefore I am considering two options:
1. Connect the alarm wire to one of the lighting wires in the loft (such as the one for the loft light) using a junction box, so they share a same breaker.
2. Replace the alarms with some battery-powered ones.
In both cases the faulty wire will be disconnected from the distribution box.
Option-1 is obviously cheaper and simpler. But my question is, is it against any domestic wiring regs or building regs? Would it invalidate our home insurance? (of course without a working alarm our insurance is invalid anyway).
Thanks for your help!
