Smoke alarms wiring
Discussion in 'Electrics UK' started by jeds, 17 Mar 2015.
  1. jeds
    jeds
    16 Apr 2004
    4,757
    Thanks Received:
    641
    Country:
    Looking for some advice on this. Aico instructions recommend mains supply from a "regularly used local lighting circuit". However, BS7671 requires all circuits of safety services to be independent of other circuits. (560.7.1)
    Any thoughts?
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,802
    Thanks Received:
    4,256
    Retired to:
    Country:
    Portugal
    Technically they (alarm and lights) will be on the same circuit so as long as they are independent of all other circuits all is well.
  4. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    The recommendation from BS5839-6 for grade D is
    The normal supply for smoke alarms and any heat alarms in a Grade D system should be derived from the public electricity supply to the dwelling. The mains supply to the smoke alarms and heat alarms should take the form of either:
    i) an independent circuit at the dwelling's main distribution board, in which case no other electrical equipment should be connected to this circuit (other than a dedicated monitoring device installed to indicate failure of the mains supply to the smoke alarms and any heat alarms); or
    ii) a separately electrically protected, regularly used local lighting circuit.
    A grade D system is
    A system of one or more mains-powered smoke alarms, each with an integral standby supply. (The system may, in addition, incorporate one or more mains-powered heat alarms, each with an integral standby supply.)
  5. flameport
    flameport
    10 Mar 2007
    10,104
    Thanks Received:
    2,037
    Poole, Dorset
    Country:
    560.7.1 and the rest of Chapter 56 is not applicable to individual smoke alarms.
  6. jeds
    jeds
    16 Apr 2004
    4,757
    Thanks Received:
    641
    Country:
    Thanks all, that clarifies it. Just for info I notice the 2013 edition of 5839-6 recommends the lighting circuit be labelled so that people know smoke alarms are also connected to the circuit.
  7. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Yes, so label smokes on the circuit.
    I generally have three notifications of smoke alarms on circuits at the board.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
