So I have an Ideal Vogue boiler installed in 2022 by an Ideal accredited installer giving the boiler a 12 year warranty if serviced yearly by an accredited installer.
I have noticed on the first 2 services that as part of BS 7593:2019, an annual on-site water test is required to check inhibitor levels and system cleanliness. Well it hasn’t happened so using a Sentinel X100 test kit I have tested the water both last year and this year just after the annual service. This resulted in under strength X100 being detected both times so I am having to yearly top up the system with an additional litre on a sealed system. Including the original 2 bottles my system has now had 4 bottles of X100 on a 2 year old system that has 13 rads including 2 towel rails in a small 4 bedroom detached 1990 built house. My conclusion is that X100 doesn’t last.
Also I have noticed that the Ideal magnetic filter is not being flushed out. Apart from that the boiler itself appears to be serviced properly.
So the questions are is it normal practice that heating engineers don’t do services to manufactures specifications by not flushing out magnetic filters and don’t bother complying with BS 7593:2019 to save time?
