    Dismiss Notice
Boiler replacement quote /ideas
Discussion in 'Plumbing and Central Heating' started by monsterink, 30 Dec 2016.
Thread Status:
Not open for further replies.
  1. monsterink
    monsterink
    2 Jan 2014
    82
    Thanks Received:
    2
    Essex
    Country:
    Hi am looking to replace my alpha cb24 this month as it keeps loosing pressure and it's old non condensing pretty 2005. Don't want to repair it. We have a baby due soon. My thinking is will be using more gas / heating so better to have something efficient.
    We have a 3 Dbl bedroom semi with a large L shape lounge separate kitchen, hallway, utility room (where boiler is) and floor to ceiling open plan landing from stairs. 1970s build
    Below is what I am getting quotes for.
    Is there anything else I should consider ?
    How much am I likely to pay ? I live in the essex area
    I've found the boiler, flu and filter for a total of 1250 ££
    Description of works below
    SUPPLY AND FIT - 29cdi 30kW WORCESTOR BOSCH GREENSTAR CLASSIC COMBINATION BOILER
    INCLUDING COPPER PIPES & MATERIALS
    CENTRAL HTG FILLING LOOP WITH CHECK VALVE
    INSTALLATION OF NEW CONDENSE PIPE FROM BOILER TO DRAIN SOURCE UP TO 2 METERS
    INSTALLATION OF STANDARD 600mm LONG HORIZONTAL FLUE
    INSTALLATION OF WORCESTOR BOSCH GREENSTAR SYSTEM FILTER
    COMMISSIONING NEW BOILER
    A MAGNACLEANSE DUAL FILTER MAGNETIC FLUSH (POWERLUSH) AS REQUIRED TO COMPLY WITH THE BUILDING REGULATION FOR ENGLAND & WALES, PART L - 2006 (BS 7593)
    A FINAL INHIBITOR ADDED TO SYSTEM TO PREVENT CORROSION
    REMOVE ALL RUBBISH FROM PROPERTY
    GAS CERTIFICATE - CP12
    BENCHMARK CHECKLIST + WARRANTY
    INVOICE (LETTERHEADED)
    Sorry about the caps.
  2. Aquaheat
    Aquaheat
    19 Nov 2007
    3,089
    Thanks Received:
    591
    Lincolnshire
    Country:
    You sound just like the customer that we would all love to have the chance to quote for! :rolleyes:
    I would say that if you get a decent quote thats within budget then take it as he's the one that hasn't put the TW*T tax on and is willing to work with you.
    Good luck and Merry Xmas.
    Jon
    • Like Like x 4
  3. DP
    DP
    10 Dec 2003
    12,409
    Thanks Received:
    2,457
    Glasgow
    Country:
    Site not seen, I would be starting at £1750 labour plus plumbing materials subject to visual inspection of site and present installation
    • Like Like x 1
  4. Aquaheat
    Aquaheat
    19 Nov 2007
    3,089
    Thanks Received:
    591
    Lincolnshire
    Country:
    Now, as you can tell I'm taking the mick but you have come on a DIY site not a price comparison site and with a crap attitude to boot. Get guys in that know what they are looking at. By trying to micro manage every detail you are on a hiding to nothing. There are many things wrong with what you are asking for already so be prepared for a spanking when being quoted if you continue that attitude as it's obvious you have no clue what you are talking about.
    Out of interest, do you have a Which? subscrition by any chance?
    Also get BG in to quote. Bet I'm still cheaper!!!!
    Jon
    • Like Like x 2
  5. monsterink
    monsterink
    2 Jan 2014
    82
    Thanks Received:
    2
    Essex
    Country:
    Thx this is good feedback I was thinking more in the lines of 1650. Max
    So I will report back
    Thanks for reply. I note this is DIY site. At the same time I know there are arrogant negative looking people like you lurking on here. Some of the threads I have read look like a **** take.
    You claim there are already things wrong in what I am asking for? Care to elaborate sherlock. This was my primary request in the post.
    Your generalisation of putting me in the which reader bucket don't help. I guess you came to that conclusion because I picked a WB and not Valiant or Intergas. Another thing I won't be calling in BG they are wasters. 4k plus quote I can imagine
    Ive recently had two boilers fitted at my parents and sisters thou there are away from Essex. Hence to requests above.
    The saying goes. If you have nothing good (useful) to say, then stay mute.
  6. muggles
    muggles
    28 Oct 2005
    11,281
    Thanks Received:
    2,295
    Daventry
    Country:
    Given your awful attitude thus far, I suspect most of the pro's on here will be following this last piece of advice from you. You seem like the worst kind of potential customer, and will end up with someone who's desperate for work (and therefore likely to not be very good) doing your job, because anyone worth their salt will walk away
    • Like Like x 1
  7. monsterink
    monsterink
    2 Jan 2014
    82
    Thanks Received:
    2
    Essex
    Country:
    I have 5 quotes booked for today.
    Thank you for your valued input. Happy new year
  8. PullerGas
    PullerGas
    11 Jul 2015
    6,065
    Thanks Received:
    1,205
    Glasgow
    Country:
    For starters WB boilers are rubbish & most combi replacements we do are no smaller than 35KW, regardless of the size of property.
    The Ideal Logic Combi 35 is a cracking wee boiler, long warranty & of all the 100's we have fitted - very, very limited problems. The Ideal Vogue 40 is a peach of a boiler, with roughly the same HW flow rate as some unvented cylinders. Then there's the range of Intergas boilers, without question one of the best, if not the best, in the UK market today. What about the Baxi/Potterton range? They have wonderful great value Combi boilers, like them all, fitted correctly they're bomb proof!!
  9. Sponsored Links
  10. bernardgreen
    bernardgreen
    3 Nov 2006
    22,423
    Thanks Received:
    2,104
    Bedfordshire
    Country:
    Consider using a heat only boiler with a hot water cylinder. The space the cylinder will take up is a small price to pay for the convenience of an airing cupboard ( babies create a kot of washing ). You will also have a good supply of hot water without the the problems of the temprature changes that occur with combi boilers when two taps re turned on.
    • Like Like x 1
  11. WLF85
    WLF85
    17 Oct 2016
    56
    Thanks Received:
    4
    Country:
    Where was the bad attitude in his original post? Why are you all so sensitive to someone checking a quote?
  12. PullerGas
    PullerGas
    11 Jul 2015
    6,065
    Thanks Received:
    1,205
    Glasgow
    Country:
    Seriously?? You think a professional is going to confirm a fixed price quote for someone on a daft forum??
    Not seeing the job, not knowing the local conditions, not knowing the fabric or construction of the building, not knowing where the existing is sited.......etc etc etc!!
    • Like Like x 1
  13. bernardgreen
    bernardgreen
    3 Nov 2006
    22,423
    Thanks Received:
    2,104
    Bedfordshire
    Country:
    No, never fitted a combi. But I have stayed in houses where a combi has been fitted.
    Having a shower in those houses can be hazardous when someone turns on a hot tap.
    The suddem change from hot shower to cold shower is at best not comfortable, it can result in a fall as the person tries to get away from the cold water..
    When the hot tap is turned off and the shower once again has hot water then the time taken for the shower thermostatic valve to react is long enough for the un-expected hot water to scald the person in the shower.
    Probably why two people I know last year had their combi replaced by heat only.
    And mind your language, it reduces your credibility even more than it is already.
  14. WLF85
    WLF85
    17 Oct 2016
    56
    Thanks Received:
    4
    Country:
    You must be replying to the wrong person because I never said anything like that.
    You still haven't shown me where the bad attitude was in his first post.
    You big sensitive fairies.
  15. PullerGas
    PullerGas
    11 Jul 2015
    6,065
    Thanks Received:
    1,205
    Glasgow
    Country:
  16. bernardgreen
    bernardgreen
    3 Nov 2006
    22,423
    Thanks Received:
    2,104
    Bedfordshire
    Country:
    but Sir Richard Puller is not registered with the GasSafe Register ( at least not in Glasgow area )
    • Thanks Thanks x 1
Loading...
Thread Status:
Share This Page
