Soak away Test
27 Sep 2005
Sussex
I have had to perform a soak away "test" in my garden, by digging a hole, filling it with water, and timing it.
The results were... slow.
Does anyone know what the times should be ?? I live in Sussex, on clay.
kojakb
hi give more info ...
is it only off a drive ... or the side of the house ... full back of house , ... have you any gully pots/drains outside the property ??????????????????
tell us then help :)
Drains at front of the house, and I've had to do the test at the back.
I would imagine that a precolation test on clay would take a hell of a long time! Never carried out a test other than on sand (which took several hours to drain).
I would image that the results will show that your soil is not suitable for a soakaway, or you will need a pretty big one :lol:
Soakaways and clay dont mix, the results will be slow.. it can take beyond 12hrs to complete 1 test.
kojakb said:
I have had to perform a soak away "test" in my garden, by digging a hole, filling it with water, slow.
Is there any other soil here.apart from chalk :oops: Is it for a foul drain/ septic tank
So any ideas as to what to do with my rain water off my roof etc then ???
well my idea is best as your a southerner , get two big water butts on the down spout of the gutter , as water shortages etc
you can can have a hose drain-off at top of butts on a sprinkler system around garden , lidl /aldi cheap shop do a good sprinkler system for 15 quid
What did your soakaway test do?? if your soil has a low infiltration rate then it just means a bigger soakaway
