I’m building a cupboard and there’s a double socket (on a ring) that’s going to be hidden behind it, which is a problem when it comes to maintenance and accessibility of that socket. I’d also like to take advantage and run a flex out to a new socket installed on the side of the cupboard.
I’m thinking that using wagos (as a maintenance free item) that I could simply join the ring and run a flex out to the new socket, however I’m unable to find a double blanking plate with flex outlet. Does anyone know if they exist and if that’s the right way to do it?
Converting the double backbox (fitted into insulated plasterboard) to a 1+1 backbox could be done, but then would I need to use a spur switch (which would also need means of access for maintenance)?
Thanks, Dave
Thanks, Dave
