Socket/light switch height? + new and old house questions
24 Jan 2006
Cardiff
I'm doing a new extension and i just wanted to clear up some questions I have:-
1. In the new extension I believe under the new rules the light switches and sockets need to be between a certain height can someone confirm this and if so what is it?
2. I'm moving some of the light switches and sockets in the old part of the house so do these need to come under the new rules and need to be at a certain height?
Thanks for any replies
Part M of the building regulations requires accesories to be sited between 450mm to 1200mm above finished floor level, but this applies to new build and fully refurbished properties only.
AFAIK as long as you do not make accesories any less accessible to disabled people than they currently are, then you will be ok.
As the BCO will no doubt be involved with this project, you would do well to just run this past him, as they have been known to sometimes (wrongly) insist on the accesories being sited at the new positions, and their word is final.
IMO, the new heights are a good idea, and once you get used to them you will begin to see the benifits.
Can their word be final if they are attempting to force you to do things that you are not legally obliged to do?
This is not an example of a difference of interpretation, or opinion on what complies, as it might be if Part M did apply but you didn't want to install things at the heights suggested in Approved Document M. It's a simple fact - Part M does not apply.
