- Joined
- 30 Sep 2004
- Messages
- 8
- Reaction score
- 0
- Country
ive got a martindale socket tester are they sutible for testing sockets are they everything i need to make sure all ok
how do i do that is that sraight from the cukai said:I have one, and yes I even use it to test all my sockets four times a year, when I test my RCD's too.
Unfortunately it does NOT detect neutral earth reversal, so you still need to do a "ohm meter" test for earth continuity etc.
kai said:Unfortunately it does NOT detect neutral earth reversal, so you still need to do a "ohm meter" test for earth continuity etc.
crystal ball said:Socket testers do not indicate high earth loop impedance, mine showed all ok, when I tested with a loop tester the ELI was 25 ohms. They are ok for l-n polarity and thats about it
E-ZE CHECK XTRA EARTH LOOP IMPEDANCE SOCKET CHECKER EZ150 - £49.80
£8 draper 13A SOCKET TESTER
Three pin socket tester for 13A sockets. Will detect the following electrical faults: no earth, L & N reverse, neutral fault, live & earth reverse and live/fuse fault. Will also test 3, 5, and 13A fuses.
Damocles said:Those enhanced specs for the Martindale would be the ones which say 'currently under construction' then?
