Socket tripping RCD
10 Sep 2015
Hello Folks,
Need help i have a double socket in the kitchen,
one on the right goes bang if you plug something in and switch it on it basically blows the appliance plug fuse and now the one on the left if i plug the dishwasher in it runs for a while and then trips the fuse where as if i plug the dishwasher into another socket it runs fine.
is this a fault with the socket and it needs a new one or could i have a bigger problem.
kind regards.
Hi, faulty socket or loose wiring. STOP using it NOW and get an electrian to check and replace the socket ASAP.
(y) DS
Just to mention if i plug the microwave into that same socket that trips the dishwasher it works fine, seems it only trips under high load due to the dishwasher.
Could be almost anything, could be loose, damaged conductor, could be faulty contacts on socket, could be the MCB is under rated for circuit.
What do you mean by appliance plug fuse?
If you mean the fuse in the plug of the appliance, then you should be thinking of a damaged/loose flex or a faulty appliance.
