Soffit and facsia before or after tiling
22 Jan 2010
Sussex
Hello guys,
Do you install your soffit and facsia before or after tiling your roof?
I was hoping to do it after I had tiled the roof, is there an issue with this?
James
you could mess up the over hangs for the gutters most do fascias first at least and gutters and soffit afterwards
If you are using plastic fascias, then you can fix the timber support board first and this allows you to fix your eaves tray, comb fillers etc, and you can set the first row of tiles out to where the gutter will be. And then fit the fascia and soffit afterwards
But that is more awkward than just fitting the fascia, soffit and gutter first
Yeah , I've done it both ways (not always out of choice) but would have to agree before is definately a lot less hassle.
