Firstly i think fascias are the upright bits that the gutters fix too, and soffits are the bits that you see if you look straight up from the bottom of your house? I hope this is correct!!!
I am going to replace/cover my gutters, fascias and soffits with upvc ones. I have been told that the fasica/soffits are in good enough condition to have them covered over with upvc. The reason i am doing this is that i think they look better and no painting!!!!
I have been told that covering them over is cheaper than replacing them, however i am not sure whether to replace or cover
I am wary of covering them, is it bad for the existing wood and can it cause problems (assuming they are fitted correctly)
I have been told that with replacing the facsia/soffits you can run into trouble with roofing problems due to disturbing the bottom layer of tiles (my house is an ex council house built circa 1950 and the roof is the original one, the council have replaced all the roofs of the houses they still own).
The other problem is the soffits are not wood, they are some sort of hard board, possible some sort of absestos?
Any thoughts?
Any thoughts?
