I need to cut back a horizontal soil pipe in order to fit a new toilet. It is 3.5" ID cast-iron and still has it's collar. There is about 2.5" between the back of the collar and the wall - Will this be enough for a chain cutter to fit around it?
I intend to hire a cutter from HSS which works parallel to the pipe due to restricted space.
Additionally - what is the shortest you should cut, or is there no limit?
Many thanks.
Many thanks.
