- Joined
- 29 Jul 2018
- Messages
- 9
- Reaction score
- 0
- Country
Hi all,
So basically just trying to do up a bungalow which has had an extension added in the 1970s which is approximately 36 inches lower than the existing build where the soil pipe and waste drainage is.
The extension has a shower room with wc which currently utilises a saniflo system, as this area is to be for guest use only it's not a problem as such until you consider power cuts, ill-informed guests flushing bits n bats they shouldn't etc.... so want to consider the option of removing said system.
If it stays - it will need a new saniflo which I gather would cost around £500?
what works would be needed to create a "run" to the main soil pipe? Can it even be done? and rough ballpark idea on cost? Thinking if it's even double the saniflo cost it would be worthwhile to do.
The area a pipe would run is just garden/soil at present, the existing house is floorboard and empty cavity beneath where most of the pipes etc run.
The 1970s extension is concrete slab flooring so no digging there, but may be able to take the pipe out through existing hole where the saniflo "sends" the waste.
will try to include some photos and a floor plan to give an idea
thanks in advance folks.
