The situation is that I am trying to complete some work that was started on the house I bought but abandoned prior to my purchase for various reasons.
The current situation involves the completion of some new soil pipe works. Internal pipes are not an issue and have been done (although not used yet so some changes can be made if needed).
The building work that had been completed when I bough the house involved two pipes sticking out of the external wall (100mm) and avilable sockets for these already linked up to the underground systems (septic tank not mains sewage).
My question is what connector should be used to connect a 110mm pipe that exists from the wall to external pipe work to keep the distance from the wall that which is needed for the pipe clips. Normal fittings such as 92.5 degree bends and even the variable bend fitting (flowplast) seem to be designed to to be used parallel to the wall not perpendicular so I assumed that a special fitting may be needed but can't see to locate such a thing on the sites I use.
I did find some examples of how to do the work on the internet but these seemed to all have a bend placed within the external wall and not a straight normal pipe.
