I'll post a photo of my predicament in due course (done, obviously!), but basically my new toilet needs to be about 100mm closer to the stack than the current toilet. Both toilet's spiggots are rear exit and are at 90 degrees to the waste stack's swept 'T' junction. The current pan connector is a tight 90 degree bend straight into the junction.
The distance from the point at which the junction diameter increases to the centre of the current pan connector is 200mm.
My soil stack is very close to the position of where my new toilet needs to go, but the swept 'T' into which the current pan connector fits is wide enough to take a 110mm soil pipe. The only way I can think of getting a closer 90 degree bend is if there was a 'T' junction that was effectively like a 110mm soil pipe and a 90 degree pan connector could be pushed further in. Does such a junction for soil stacks exist, or is there some other way I can get a tigher 90 degree pan connector? Please don't recommend a side exit pan, because, as usual, I'm not the one in charge of picking the sanitary ware!
Apologies if none of this makes sense, but I'm not sure of the proper lingo!
Any constructive advice appreciated!
-Rob.
-Rob.
