I have put the clamp-on on my tails, and one by one, turned off RCBO's one at a time and watched the reduction in power use, and I see a drop, with socket circuits switched off, but I can't relate this to items I know are on the socket circuit, can't use the solar software to monitor as turning off sockets, would turn of router, and hard to monitor freezer and fridge use, as supplied from the UPS direct from the inverter.
Around my consumer unit there are a few CT coils, and I know these coils can affect each other. And the use of grid power always shows a little higher on the solar software to what is shows on the IHD or phone app.
Often the figures don't add up on the solar software.
Some where 47 watt has gone, however some of the data is live, and some by the server somewhere in China. However when looking at more long term data,
seems to line up with the app far better. Looking at the week 19-25 May export £14.27 import including standing charge £6.25 so clearly not costing me anything at the moment, and my account balance is increasing every month, at the moment £164.47 but this is summer.
Last winter I was not being paid for export, and I was on 8.95p/kWh off-peak, and 31.31p/kWh peak. I used the data to work out what it would cost with a fixed rate. And it showed I would have paid at least £25 more had I used a fixed rate, as many days in the winter my solar production does not exceed used.
So December 2024
yes battery shows as charging 24 more kWh to discharging so clearly some loses. So the phone app shows
without standing charge and
with standing charge. So £75.51 total for worse month, year before did not have smart meter, so no off-peak, and paid around £100, and year before that more like £150, so the off-peak clearly cut my bills. But since export was only 13.9 kWh so just over £2 so I can expect the same cost this year, of around £75 for December.
I would be paying a lot more, if I did not have a battery and off-peak, but solar for month is likely only around £24 for the month, so mainly in winter it is the off-peak and battery saving me money, summer of course very different, this month alone around £127 produces by solar (at 15p/kWh) but need to look at the bad as well as good, and I don't want to be swapping tariffs, I now want to forget the electric bill been there, done that.
