surely soldering must be a better connexion than a mechanical joint?
To solder two solid wires together:
Strip about 2 inches of insulation from the end of each wire
Place the bare copper sections parallel to each other
Wrap thin copper wire tightly around the two wires to bind them together
Apply heat to the joint
Apply solder to flow over the entire joint filling any gaps
Remove heat
When cool, cover with shrinkwrap.
