when soldering 15mm pipe,roughly how long should I leave the blow lamp on the fitting?Also are there different diameter solders for different size copper pipe or does one do all.If so what diameter solder reel do I need.Thankyou
tinman said:1.clean pipe end your going to join with steel wool
JPC said:finger....?
i dont think so !
how about a flux brush !
tinman said:you can get 15 and 22mm piping and joints with solder already in them, these are called yorkshire welds, if u go out to buy them.
plus if ur gonna solder then heres a step by step guide>
2.use your finger to spread some Flux on the join area
3.place the two joints together and heat till the point where when the solder touches the joint it melts freely.(with the ready soldered joints u heat the joint till the solder bubels out.) also if the space is tight use a heat proof mat to shield the surroundings.
4.leave to cool and then wipe off any excess Flux as if its left on it could corrode the joint.
