Solid fuel burner
12 Dec 2008
Warwickshire
I would like to fit a solid fuel burner into a caravan, the carvan is a 30feet by 10feet static. The only heating i have is the fitted gas fire, hence the solid fuel burner. I would like any advise in the safe way of fitting the burner, such as size of the burner, any heat protection i need to use and what type. Also can the flue from the gas fire be used for the solid fuel burner or does it need to be changed. Thank you
Speak to the manufacturers. You have no redress if you get information here.
