Anticipating a new Gas Central heating system to be installed, I had the chimney taken down and I removed the chimney breast from the kitchen. I now want to get rid of the old solid fuel boiler, whilst awaiting the new system so I can make good the wall and then dry line. The solid fuel system has been condemned so is unusuable. All I want to do is remove the so called range, but still use the immersion heater for hot water.
The current system runs off a header and feeder tank in the loft, with an additional immersion heater fitted below. The hot water system can run independent of either the solid fuel boiler or the immersion, but the central heating did run off the boiler only via a pump in the airing cupboard, which had to be manually switched.
The two tanks in the loft space have isolation ball values, so if I turn these feeds off, will this then allow me to drain the central heating system, so I can cut and seal the 28mm boiler feed pipes in the kitchen loft space?
I have removed the radiators on the first floor and only have four on the ground!
