Solid fuel + GAS CENTRAL HEATING
17 Oct 2009
On the advice of another member i will try again
I have an LPG boiler but is expensive to run so i want to run it along with a wood fired back boiler BUILDING REGS no problem as i live in Romania now but safety is.
Can i fit an expansion vessel on the wood burner and a pressure relief valve as i dont want to have a water tank in the loft ??
Thank you in advance
NO,- SOLID FUEL SYSTEMS MUST BE VENTED i.e Header Tank.
This is to prevent elevated temperatures which could be very dangerous, with an open system the water cannot exceed 100'c :wink:
Many many thanks for the reply its what i thought was correct but they do sell and install wood/coal boilers here and install them with an expansion vessel.
So is it a problem to link it to my LPG boiler as the wood burner would be conected as if it were a radiator ? i would of course be putting a pump on the wood burner.
