Solid insulation and down lighters
  • Thread starter Thread starter STI
  • Start date Start date
STI
5 Aug 2009
Birmingham
Hi. Does anyone know of a downlight fitting that is designed to go into solid insulation. Or is it a case of fitting a normal one and cutting back the insulation by 100m all round..
Flameport thanks, so does that mean you cant put downlighs in a roof with solid insulation.
Yes. But you could bodge it with a joist spreader thing (metal "shelf") and lay insulation over that. But it'll still hold heat close to the downlight, which you dont want.
  • Thanks
Reactions: STI
So i guess another option would be LCD fittings or do these run too hot as well
LED. No, they run a lot cooler. So do PL downlights (google) and CFLs.
LEDs still require clearances - they may not produce much heat, but they are very intolerant of that which they do, and it must be dissipated or they will fail.
But any recessed light is going to be problematic, even of it needs no clearance at all it will still require a light-sized hole in the insulation.
And we've not begun to consider vapour barriers, condensation, rot and mould and yet another Building Regulations contravention...
