Solid stone wall insulation.
24 Jan 2016
The age old question...how to insulate our internal walls of our solid stone built barn?
I have read lots on this site and I'm still confused.
The walls are sandstone,about 2ft 6in thick and seem to be doing a very good job, no mould, no obvious damp etc.
We are planning on having a GSHP installed with underfloor heating throughout so we must insulate the walls in order for this heating method to be effective.
I have been advised that a slurry coat ,75mm insulated plasterboard (dot n dab) and then plastered is the way to go.
Any thoughts,
Thanks in advance.
What is your "slurry" coat" for, the walls should be parged, to make them air tight if you insist on using dot and dab. I have some dot and dab walls and under high condensation levels (14 p*** heads at a dinner party) the dot bits go dark with moisture.
Are you sure that the walls are , A, solid, B, watertight?
Frank
