I am about to start a full refurb on a Solid Stone Wall Town House from around 1850's. Heating, Electrics, Plumbing, Insulation, New Windows, doors etc... the works.
All advice read around the web is I need to be careful insulating this type of house. As solid stone walls need to breath.
From what I understand, a typical incorrect insulation is using insulated plasterboard internally. With nowhere to go, moisture reaches its dew point on the impermeable material, creating damp patches on the wall.
I can't cover the outside because of aesthetics. Anyway, covering the outside with non-permeable render can prevent internal moisture from escaping, again creating internal damp.
So basically I need to be careful what materials I use to make sure the evaporation will keep dampness levels in the building fabric below the levels at which decay can start to develop. Basically creating a 'breathing building'.
My basic understanding is I can't use run of the mill cavity wall insulation? But surely with all the advances of late there must be a Insulated Plasterboard & process I could use?
Can anyone suggest what approach i should take?
Thank you so much for your advice & help. Truly gratefully appreciated.
Here's a photo of the walls. It's an old house in need of a full refub, but there's no damp. It's good & solid. It's has big thick stone walls: 50-60cm. Currently has no ventilation, i plan to drill vent holes in each room (or the fact that chimneys are in each room, would that suffice?).
