- Joined
- 23 Jun 2019
- Messages
- 26
- Reaction score
- 0
- Country
I own a 1900s Victorian end terrace. My side wall is on the boundary and adjoins 4 neighbouring plots of an adjacent road.
On clearing out the end neighbors garden yesterday, in preparation for some minor render repairs, I noticed that it's in much worse state than I first thought in places, so will probably need to be replaced. I'm not sure whether the existing is lime or concrete, will test ASAP.
I'd like to insulate this same wall internally, the fact it's a boundary wall pretty much puts insulating externally out of the question. For completeness, a previous owner has poured concrete floors at some point, which is causing damp problems on some internal walls, but not the one mentioned above as far as I can see.
So my question is whether I'd be best off trying to maintain breathability in the wall, by using lime render and mineral wool insulation (considering it has no internal sub floor ventilation now) or try and seal it off to moisture with cement render and PIR insulation (preferable due to the smaller dimension) and possibly DPC injections for good measure.
Fwiw I hope to install a whole home dehumidifier at some point to keep the air inside drier in general. At the front is the original brick facade with line mortar and at the back is a concrete block extension with concrete render on the adjacent elevation too the one mentioned above (I think).
It's also my first post, so hello and please go easy on me
