Good afternoon, in the process of tidying up my home, at present i have got a concrete floor ready for insulation, underfloor heating pipe and screed to go on, (so original floor height - 170mm) and ive taken off the render off the walls.
Question is, what goes on first. the sand/cement render + finishing OR insulation, pipes and screed?
It doesn't matter which you do first, because the screed and the render(you also referred to it as plaster; they're not quite the same thing) should
not be in contact with each other. The perimeter of your room should have a strip of insulation, 25mm kingspan for example, that the screed will run up to
You won't get any screeder worth his salt to lay a sand and cement screed at 50mm; it's too thin and will break. 50mm is ok for liquid screeds (I still have no regrets about mine despite many people saying "don't do it") and with additives they can be 40mm if needed but a sand cement screed will be more like 75 mm. If you're having underfloor heating, put as much insulation in as you can, and make it kingspan, not polystyrene. Your floor is your radiator, it needs thermally disconnecting from the ground below as much as possible, otherwise you're paying to heat the mud under your house
Officially, underfloor heating pipe work should be pressurised with water before a screed is laid on top of it, and it should be at a pressure beyond what it will be run at when in service. This will highlight any leaks or damage, and it will ensured the pipe is expanded slightly more than what it will when in service, minimising the risk of damage to the screed. Hard as it is to believe, the pipe expansion can be enough to break the screed when the system is pressurised
As has been noted, the uh manifold can be put in place temporarily, then unscrewed, bent out of the way(the pipes remain flexible, the manifold should be around half a metre off the floor) and the wall rendered behind it. Alternatively, render first, even if it's just the one wall where the manifold is.. Saves your 500 quid manifold getting covered in mortar
