solid wall question
15 Apr 2005
Yorkshire
My house has solid external walls. If I were to have an extension built, would the extension require a cavity wall?
Not necessarily no.
But, it would have to comply to the latest reg's which in practical terms means a wall thicker than the existing solid fellas.
Building with a cavity means that all the insulation required can be hidden in the cavity, leaving the inner walls free and solid. *It is also the most economical method.
*When using 100mm full fill dritherm.
[it would have to comply to the latest reg's which in practical terms means a wall thicker than the existing solid fellas.
I'm pleased to see you say that. I've just rebuilt an old single brick extension on my Cotswold stone house, with brick/block and 100mm cavity filled with dritherm. The odd thing was that my architect and a couple of builders tried to make me have the insulation on the inside of a solid wall - still cannot understand why!
There may be a possibility of a timber frame, with external single skin brickwork, and this may be close to the 230mm or so of an old solid wall
