- Joined
- 31 May 2016
- Messages
- 28,705
- Reaction score
- 7,592
- Country
school?Did you not learn that in science lessons at school?
is that when it comes unstuck?9.81m/s2
Yep - size matters:Providing the adhesive is applied to the entire surface, it will scale up just fine. The only issue is that if an edge, begins to peel, that can drag the lot down, and so edge support might be needed, until the adhesive drys.
Compare it to wallpapering a ceiling...
A small piece of wallpaper will easily stick to a ceiling, a full length will be more difficult, because the ends will tend to unstick, and once the ends unstick, the lot comes back down.
Ahh, gotcha.Did you not learn that in science lessons at school?
I didn't expect that for pins. I know some spiders can walk on water.Did you not learn that in science lessons at school?
Who wallpapers a ceiling?Providing the adhesive is applied to the entire surface, it will scale up just fine. The only issue is that if an edge, begins to peel, that can drag the lot down, and so edge support might be needed, until the adhesive drys.
So why do the ends unstick! Another science question. I have no idea.
The pin floats because the weight is not enough to break the surface tension. If you put 1000 pins next to each other, I would expect them to float as well as long the surface tension is the same. In reality I suppose the presence of 1000 pins will disturb the surface tension, which is why we don't see a Youtube video of 1000 pins floating.
If I have an adhesive that holds a 1 cm x 1 cm tile onto the ceiling, will the same adhesive hold a similar tile 2 m x 2 m onto the same ceiling? If not, why not?
Before you say it's heavier, consider that the adhesive is providing the same force per unit area for both tiles, and the force of gravity per unit area for both tiles is also the same...
I asked 2 different AIs this question. One said it was due to imperfections, as if there are no imperfections in the 1 cm x 1 cm tile scenario. The other AI in the end agreed with me because I was relentlessly harassing it!
It is a complex interaction of surface area and wetting angle. Things I barely remember. If all the pins are touching in one big mass then it will sink. But if there is a sufficient gap between each pin they will float.
The temperature of the water is relevant. It doesn't work with hot water.
