Some DIY patio advice?
Hpd
23 Feb 2011
Cardiff
Hi guys,
I’ve got a lawn that gets quite boggy and ideally I’d like to turn at least half of it into a patio, so just after some advice!
What’s involved firstly in terms of preparation? How much to dig away, what to put down as a sub base etc?
What sort of fall would a typical patio have? And any other tips or pointers would be great!
Thanks I’m advance
What are you having for your patio?
For Indian sandstone, I've used 100mm hardcore, whacker'd down, then around 50/60mm of bedding mix, 5:1 sharp sand to cement.
Use a full bed, not 5 spots.
Wash the back of the slabs, some use primer, some don't.
Fall, think 1:60 is average but around 10mm per meter seems OK to me, depends on conditions.
Thanks for the reply. Not sure yet but possibly the sandstone you mentioned. I’ll watch a load of YouTube videos to see if it’s something I feel able to do lol. How difficult is it? And does it take long? Vague questions I know but just figuring out if it’s possible for a DIYer
Thanks for the tips and the suggestions for tools. Very tempted to go for it!
I've had the usual natural riven faced sandstone before at a previous house. It looks nice but, whatever slope you have, water will collect in the natural dips so they will go green or black fairly quickly. It's not the biggest deal in the world, but it used to annoy the obsessive in me.
At the other end of the scale, polished stone can get slippery.
Next time round I'll be getting sawn or sand-blasted finish. It's easier to lay and looks blooming stunning when done right. I don't know how the price compares though, I could still be persuaded to get the riven faced if there's a huge difference.
Concrete can also look absolutely fine, if done carefully. They look much better if spaced apart and pointed, as you'd do for stone, instead of just bunging them next to each other.
Whatever you get, use a decent gradient level and some string line.
  • Thanks
Reactions: Hpd
I'm doing the same thing soon but using brick pavers, what people often use for driveways. Cheaper and easier to install, or adjust later.
