Very useful info, thanks.
Just to ask a stupid question but would you expect water to flow out of the LS valve? In my head I imagined that side of the rad was the water flowing down the LS pipe rather than pouring up.
The balancing wasn't professional to that degree so I'll retract that statement. But he tried balancing from the nearest outwards then when the inlet pipe failed to heat in the furthest away radiator (also the problem radiator) he balanced backwards. One thing I do know is it doesn't matter what position the other 6 working radiators have the LS valve set, when you turn the TRV even an centimeter from the off position you hear a rush of water and it heats very quickly.
The other 3 just seem so far away from working the same although I can confirm that the pressure on these faulty rads is pretty strong on both valves when loosening off the nuts.
