Some taps calls for hot others dont
30 Dec 2011
Yorkshire
Hi
I recently had problem with my Baxi 105e which i had to change the pcb but now i have a problem that my wash hand basin and shower wont call for hot water both have been ok till this morning and my bath and kitchen sink are working fine. Any ideas
Cheers
Richard
Hi I would say you need a new diaphram its available on ebay quite cheap and an easy diy fit just search on here for it theres loads of threads
hope this helps Paul.
Better to measure the flow rate in litres per minute at which the boiler just turns on.
Should be at about 2 li/min.
I expect you will find the flow rate at the problem tap is less than what your faulty boiler needs now.
Tony
Tony
Thanks I will check but what i havefound is that if i turn them both on the boiler fires up and then turn one off i still get hot water. So i guess the flow rate might be down but what would have caused it and how can i put it right?
it is not that your flow is down...it is that your diaphram is now worn and needs more flow to move it .
your not getting this much flow through some taps when they are turned on by themselves. open another tap and you are increasing flow past the diaphram , hence it starts working
you can do things to make it work now but it will only get worse untill it doesnt work at all
its a common part to be changed on theses boilers around every 5 years
Chris
