I have to access the ends of 3 self-tappers 1 foot down a 6" internal dia flue pipe, to grind them out.... while balancing like a ballerina on my roof ridge tiles.
I`ve removed clag/tar but my £80 new in 1984 Bosch 4" grinder & the slitting discs I`ve used since I retired the hacksaw, is not a safe bet. Can`t use a drift & hammer either, pot`s too fragile.
I can`t work over the pot. There is so much weight, 20ft of clagged-up pipe, I can`t lift from the top, or jack up from the bottom(I tried), the flexi liner to get the cowling & sleeve above pot lip height to access the screws to undo, so have to grind them out internally to allow the liner to drop down into my room. I could grind the top of the cowl off, but I`d prefer not to. No welding gear anymore.
Can anyone suggest a cheap bit of kit that has one foot reach & grinding capability for confined pipe internal?
